Rogue Leader
Eat my valvestem caps!!!!
- May 25, 2001
I got a leak from what appears to be the oil pressure sender, but its farily new, the mount it goes into that also holds the oil cooler in was a little loose and that SEEMED to cure the problem but it started to leak again within a few miles, its not loose anymore.
The oil pressure gauge works perfectly so i know teh sensor is functional, could the mouting nut go bad, is that a rare part??? Only leaks when the car is running BTW, AND when i first fixxed it it was fine idling in my driveway a few times then i took it out and droive it and hit the boost a few times and it started back again...
