Oil pan and oil stem pipe removed
anthony mendoza
what are the procedures and steps that I have to do to remove the Oil pain and the Oil stem pipe for my 87 grand national do I have the hoist motor or does the oil pan slide right out when you take off the boats please I need help
It will come out w/out taking the pump pickup off. You may have to rotate the crank a bit, to clear the counterwts.
I've aways removed xpipe ,remove long eng mount bolts,jack eng couple inches give u little more working room. Use cork gasket.
