highboostgn
- May 24, 2011
Anyone know it? And the pattern?
Thanks,
Donnie
Thanks,
Donnie
SignUp Now!It's 10 Lbs of torque thats very light. I've always started at the corners just to get the pan and gasket in place. I've also only done this laying on my back!! Just get the threads started in each hole then torque them down in a criss cross pattern.
TurboDave said:You mis read. It's 10 Nm not 10 lbs. which is 88 Lbs.
That's 88 inch lbs not 88ft lbs88ft lbs?
EVIL said:I always torque my pan more than my heads.
I bought an "inch pound ratchet" at Autozone fairly cheap. It works great.
D
I used a cometic oil pan gasketUsed a felpro. The blue ones. Replaced and torqued all to 88inch pounds except for the front 3 I couldn't get to with the torque wrench and had to a regular wrench. Leaks worse then it did before and my fans stopped working too...only in a TR.
