ECM provides a 3 second prime pulse to fuel pump then shuts off. then the oil pressure switch turns pump on after oil pressure goes above 4 psi . Then when ECM detects a run condition it closes the relay to the on position . Oil pressure switch fills the time during cranking between the prime signal and the engine running signal that the ECM puts out to the relay
