Tim Cucci
- May 24, 2001
Can I have to much oil pressure? Priming the engine with a 550 RPM Drill Motor I get  55 PSI. Wonder what this will equate to at 750-850 RPM Idle. Oil cooler lines are hooked together at this time also which I don't think will make a difference anyway?  High Volume Oil Pump also.
Tim
Tim
		 Good luck with the new build.
