Oil Pressure Relief Spring/piston
SPOOLIN
Fellas, when removing the spring in the oil pump housing is the little piston in there suppose to pop out also or is it suppose to move around, cause i stick my finger in there and i cant get it to move at all. im trying to figure out my low oil pressure at higher rpm. thanks
The piston should move freely in the bore. You should be able to take it out no sweat. If not somethings wrong.
