forcefed86
- Jul 28, 2005
I'm a little confused. This is a new pump housing and gears. Usually when you drop the 2 gears in you line up the dots on the gears.
Usually they are like so...
My kit has the dots on 1 tooth of each gear? And the dot is really a stamped "t" like the attached image. I'd like to know the correct orientation of the T marks on my gears.
