Oil temp sender at turbo lube port OK?
tminer
Not quite normal
Using tee(s) of course, or should it be in the pan?
Thanks,
Tom
Low in the pan is best.
If you have a remote filter, then a T in the line, would be a good second place.
I'd worry about the Turbo area causing an error from radiant heat. Maybe some one's BTDT, on that issue, thou.
