I typically run around 85 psi hot with no crank problems due to oiling. The front cover needs to be ported to flow enough to prevent oil pump cavitation. Later pump covers also have a groove machined into them to prevent cavitation. If you see pitting on the pump gears, this may be the problem...the gear teeth are chattering. I also use regular, soft, stock replacement bearings from Federal Mogul, instead of the harder "race" bearings that some use. I've found that alky is very detonation prone if you run it too lean. I've actually had a wrist pin hammered out by lean fuel. It could easily score a crank as well.
GB
