i just ordered the dual nozzle alky kit from smc and can't wait to get this thing...i was told to get the dual setup because of my mods...now i have a couple questions...i have never used alcohol before and i still don't understand exactly how it works...i know it allows me to run higher boost levels on pump gas...
how much boost is possible on my te-44 turbo with my 22 degree timing chip? i was wanting to run at least 23 lbs...maybe 25 lbs...is it the more alcohol i spray the more boost i can run? i know i gotta watch knock...just curious as to how high i can turn up the wick on this baby...i don't even want to be touched on the street
also what kind of alcohol is THE BEST to run? i heard denatured at some kind of mix is...wouldn't straight 100% denatured be the best? i can get this stuff easily at work at a discount so i am not worried about cost...if not 100% am i supposed to mix water with it? i also ordered the lube for whatever purpose it serves...
also with this kit...is it setup where one nozzle sprays at say 15 psi and the other sprays later at like 20 psi? or do they spray at the same time...i also ordered the 1 gallon tank because i know damn well i will be going through alky like water
