Okay what next
PhantomTA
Supreme Overlord
Okay car is a 98 GS for those who dont know. I have done a few things to far.
Modded the stock airbox slightly and added a KNfilter.
Taylor wires
180 thermo
Removed U-Bend/Resinator/Cat
No engine cover or hood liner
After doin the exhaust work all my knock retard went away! i did notice a tad bit less boost tho. :/
I have a 3.4 Pulley on order...
So whats next?
Cheaper the better :)
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
what next
on a 98 regal your coolant bottle is in the way of your air box. you need to move it. if you have a late production 98 just buy the 99 coolant bottle from the dealer or 3800perfomance.com. if you have an early producyion 98 like mine the abs module is in the way and you to fab a bottle. i used a bottle from a kia sportage and mounted it in front of the radiator. now build or buy a cold air intake. you will get more benefit from a cold air intake than just modifying the factory box(especially on a 98) next step is exhaust- you need a less restrictive muffler & cat (3800performance.com or dennis meacham)
i already removed the cat resinator and u bend (as noted in original post)
i dont think the muffler will do much cept change sound.
ill be doin that coolent tank next.. i believe i have a later 98 so im all good.
thanks
anything else?
