with the wastegate off the car, zero load and hooked to an air pump on it how much air psi should i get when it just starts moving out, half and full extended? im getting 18 psi to just get it moving, 22 psi half way and 26psi full length. my guess is that it is defective when i borrowed a friend wastegate that leaks with pressures above 16psi. it only took 7psi to get his moving. please help my wife drives the 87 GN more than I do and dont want her to pop a head gasket because i cant lower the boost below 20psi. please help and thanks in advance.
