87grandnational
- May 29, 2004
seems like it does,.. just wondering.
SignUp Now!Originally posted by Shane
But wouldn't a turbo provide all the backpressure you could ever want?
Originally posted by BuickMike
Shane is correct
HAH! No one's ever said that before. Now could you just tell my girlfriend?![]()
Originally posted by TurboDave
John, you'd be amazed at the amount of backpressure the turbine housing produces!!
In a typical stock turbo it is close to a 2 to 1 ratio (for every pound of boost there's two of bacpressure) over boost, and a fairly efficient turbo will still produce something on the order of 1.5 to 1 backpressure to boost ratio. Some turbos have been seen making a 3 to 1 backpressure to boost ratio.
All this backpressure I'm refering to is in the exhaust manifolds/heads, pre turbo. That's why it's imparative to keep post turbo backpressure to as close to absolute zero as possible.
Originally posted by GNVenom
Thing you gotta watch out for is lack of backpressure with the dump open. Backpressure in the exhaust is necessary to maintain proper quenching of the cylinder. Too much backpressure and the cylinder doesn't quench enough, leaving exhaust gas in the next cylinder's mix. Not enough backpressure tends to suck the unburned mix out before the exhaust valve closes, causing a weaker AF mixture, and lack of power.
I see this happen all the time with these Honda guys who think that a loud free-flowing exhaust without cat or muffler can make the car go fast. Instead, it has just the opposite effect. All you do is upset the balance with that line of thought.
