87 WE2
- Jun 28, 2002
Link to pictures: Parts for sale pictures by turbo231 - Photobucket
Money orders & paypal accepted, + 3% for fee's.
Interior:
Center console shifter plate appliqué (just what is pictured)
G-body parts rear restored middle belt
Nice Blue glove box, no key
Radio installation kit and wire harness adapter
Mount for cruise control box under dash
Brake switches for brake pedal
Turn signal stalk, non cruise
Chrome door lock thing
Door escution, small crack near pull strap
Boost knob bracket
Center console cable grommet (2) available
Seat belt trim piece
Clarion head unit and cd changer
Trunk release button
Dash pad, gauge surround, gray was painted blue. Needs repaint to be perfect again
Gray B billar moundlings, pair
Windsheild trim Gray, not perfect.
Passengers side window Switch
Super MINT wood grain buick regal dash plaque
Instrament cluster plastic support
3 dash vents
Transmission:
Trans wiring clip
D5 converter
Tran’s cooler line mounts to cooler
Trans stock servo parts
16 stock Trans pan bolts
Tran’s cooler line set
Suspension:
New MOOG tie rod adjusting sleeves
Frame mounts and bushings stock front sway bar
Center link
Inner & outer tie rid assemblies with adjusting sleeves
2 good stock calipers
2 good stock brake rotors
stock rear sway bar
Wiring:
10K mile tail light harness
10K mile cruise control harness
Exterior:
Original valve stem cap set
New GM door lock cover set black trim (3)
Locking fuel cap
Antenna nut and sleeve for top of fender.
Rubber isolator for fuel lines atop gas tank
19 used lug nuts, good for driver
Bumper spacers, gloss black powder coat
Engine
Original GM vacuum block rubber vacuum hose coup link’s
Oil cooler line clip
86/87 used original ECM
86/87 used original MAF
Set of factory original valve springs
Oil pump parts
2k miles on new B&M Oil cooler
Good GM 02 sensors
Heavy duty IC hose turbo to IC
Water temp idiot light sender
Taylor spark plug wire clips
Factory oil cooler adapter
AC line plastic cover, larger one
EGR non ac-delco, working
T-stat housing
Stock stat new
Stainless T bolt style heavy duty house clamp 2”
MAF tube good for driver
Horns
84/85 Oil dipstick tube, powder coated gloss black
Exhaust elbow
New 2 ¼” band clamp
Vacuum block nice used original
AC Delco EGR valve 2k miles
EGR plastic cover
EGR solenoid bracket with nut, powder coated gloss black
EGR solenoid 2k miles
GM 3 bar map, used for testing. Otherwise brand new
IC fan with bracket painted aluminum color and cleared
Factory power steering non pressure hose
Turbo crank shaft std/std, rear thrust surface worn. Will need over size thrust bearing rest of crank should polish out, may need cut .010
Power steering pressure line
Coolant over flow bottle
AC dryer, Blue cap covering 134 fitting removed
Good wiper motor
Good windsheild washer fluid pump
Tools:
Jack, brand new good for track
Air hose 25ft
Trim clip tool set, new
Valve spring compressor for taking heads apart that are removed from the engine. Bought new, used once worked great. Comes with plastic case. $50 shipped.
If you do not see a picture of a part just ask, I can take some and send via e-mail or post in the thread.
Interior:
Boost knob bracket
3 dash vents
Transmission:
Trans wiring clip
D5 converter
Suspension:
Center link
stock rear sway bar
Wiring:
Exterior:
Locking fuel cap
Engine
Oil pump parts
Good GM 02 sensors
T-stat housing
Stock stat new
Horns
Exhaust elbow
New 2 ¼” band clamp
EGR plastic cover
Good wiper motor
Tools:
Air hose 25ft
