I have a 363 ford with decent compression and all the good internals and a custom grind solid roller nitrous cam that i am trying to get tuned so i can just drive the thing(without the spray).
I am getting closer on the V.E. table but its such a handful on the street that it is rather difficult(drivability is pretty poor). Does anybody have a similar cam (649 lift int & ex. and the .050 duration is 268int, 276ex, lobe sep is 112 it is installed on a 108 c/l for N/A use at this time. FAST sequential with WB and ind cyl control. will i ever be able to drive this thing on the street or am i beating a dead horse here. It is in speed density mode now it idles well at 1100 rpm with 36 degrees of timing at idle. I was running it in O/L at idle for awhile but i am thinking of trying closed loop again as it seems to be loading up at idle. thanks in advance
Andy Fears
Andy Fears
