TURBOTIMMER
- Jan 5, 2002
SignUp Now!PM sent.
bw jones
all parts listed for an 86-87. shipping extra unless specified:
-main accessory bracket. SOLD
-y shaped alt. bracket. SOLD
-L bracket behind access. bracket. SOLD
-low mileage tensioner. SOLD
-y bracket behind alt. SOLD
-a/c compressor. worked good when pulled. I deleted my a/c. SOLD
-tensioner with broken ear. $10
-2 sets of hard vacuum lines. (going under the tb) $30 ea- 1 LEFT
-3 cam sensors. $40 ea 1 WITHOUT THE CAP LEFT
-1 cam sensor with broken ear. still worked when pulled. $10
-ps pump. SOLD
-pass side relay bracket with relays. $30
-egr solenoid. no bracket. $20
-heater control valve from my 59k mile car. worked fine, I just wanted new and shiney. SOLD
-3 wastegate solenoids. discontinued from GM. $40 ea.
-both coilpack brackets. ALL SOLD
-2 stock turbo elbows. SOLD
-stock ic fan. got a little too close to the ic. $20
-billet inlet bell for bigger TA style turbo. SOLD
-crank sensor and bracket. worked when pulled. SOLD
-stock balancer. SOLD
-stock ic brackets. driver's side modded by some idiot. $30 for the pair
-stock fuel lines from frame to fuel rail. 2 feed and 1 return. $30 for all 1 FEED LEFT
-stock inlet bell. $5
-hard heater core lines. also have the fitting for the intake. SOLD
-cut up stock ic with dutt neck. I also have another ic I cut in half to make a stretch, but never got finished. $75 for all
-3 starter heat shields. $5 ea. 1 LEFT
-a/c lines. 2 sets. $30 ea.
-a/c condenser. also out of my car. $30
-new casper's ground stretcher kit. SOLD
-charcoal canister. SOLD
-Radiator hold down plate. not perfect, but decent. $40
-breather heat shield. Goes behind the turbo. SOLD
-oil cooler adapter and lines. Lines are kinda cruddy, but they didn't leak. SOLD
-2 driver's side headers, 1 passenger side. They all need work. ALL SOLD
-3'' aluminized testpipe. has 3 bolt header flange welded on the motor side. SOLD
-pair of rear exhaust hangers. They bolt to the frame up near the spring. SOLD
-2 engine wire harness's's's'. One was on a running car, the other was for parts. SOLD
-plastic vacuum block. SOLD
PERFORMANCE STUFF:
-RJC power plate. new with gaskets. SOLD
-100lb valve springs. tool included. SOLD
-used torque strap. no eye bolt, just strap. SOLD
-atr ramair air cleaner housing thingy. No ductwork or air cleaner. SOLD
INTERIOR:
-new GM burgandy shifter handle. All new chrome rings and buttons. SOLD
-burgandy steering wheel. Not leather. no parts just wheel itself. Good for a core. $20
-2 gauge bezels. one is from an n/a car. no "3.8turbo" emblem. the other is from a turbo car, but has the wrong color insert around the defrost button. Both are very nice. ALL SOLD
-radio bezel. also nice. SOLD
-grey dash plaque from 86 t type. just says buick regal. decent shape. $20
BODY:
-87 chrome grille. nice driver quality decent chrome. no cracks. "buick" emblem included. new ones are $400-$500. this one is SOLD
-turbo t hood ornament. good driver quality. SOLD
-driver's side chrome taillight. driver quality. has small crack in the reverse light lens. not bad, though. $30
HOT AIR:
-std block. 14 bolt. was supposedly rebuilt before I got it. I tore it down to check it out, and it appears that it was. $50. WILL NOT SHIP CAN'T BELIEVE I STILL HAVE THIS
-std bore stock turbo pistons on stock rods. $50
-14 bolt baffled oilpan. A little banged up from moving the motor around while it was still together, but still useable. $30
-2 hotair intakes. 1 is basically complete, the other isn't. $30 for both
I think I've priced everything more than fair. Add everything up and it comes out just over $2000. I would rather sell as a package deal, but if I don't get any interest within a couple of days, I'll start splitting it all up. I'll take $1200 for everything as a package deal. Email me at turbotimmer@hotmail.com or post here.
