Paging Onlya6
  • Thread starter Thread starter Last of a Breed
  • Start date Start date
L
Last of a Breed
Guest
Hey, you replied to one of my threads about getting a street/strip trans from Cottons. Just wanted to know if you know how long would it take Cottons to install it? I'm asking becuase I've heard that they're a small shop. Thanks
Kevin
i have his trannies in both cars. they are built by Eric Schertz of dyno tech performance. i have not had a single problem with either. one is the street/strip l/u tranny (975.00) the other is a balls to the wall non l/u race tranny (1500.00) i usually call ahead, make sure ones at the shop, if not place an order, then make a day to travel down to the shop. if your lucky he'll do it right then and there, sometimes hes busy and he'll want you to leave the car. theres a good thread on his forum in the tranny section called "cotton's trannies". be sure to call him before you head down to his shop.http://cotton.phpwebhosting.com/phpBB2/viewtopic.php?t=49
Thanks Matt87. I'm considering purchasing an 87 Gn at the moment, and the owner said the clutches needed to be replaced. So I was figuring I might as well just replace the whole thing and start from sqare one to avoid problems. At least I know there's a chance I can get it done rather quickly. Thanks for the input.
Kevin
Kevin, everything that Matt said is absolutely correct. The best thing to do is call and make an appointment for a day when he will be able to do it all in one day. Even if you have to wait a couple of weeks its better than having to leave your car.
Jacob
