paint code
first turbo
WHERE CAN I FIND THE PAINT CODE, ACCORDING TO DUPONT THERE WERE 2 BLACKS USED IN 87 CODE 86 KALAPANA BLACK &CODE 14 BLACK, DON'T HAVE EITHER CODE NO. ON THE TAG IN THE TRUNK. CHECKED DOOR TAGS NO LUCK.
THANKS DON
Paint code is found on the RPO trunk sticker and on the Fisher body plate located on the firewall(driver's side above the wiper motor) 19U Black Lacquer
Additionally at the bottom of the RPO sticker is code U.WA848
which is also the code for Black Lacquer paint.
I believe GM officially called it Tuxedo Black and the trim was called Lamp Black
THANKS, FOR THE INFO I HAVE U.WA848 ON THE STICKER. I HAVE BEEN SHOPPING FOR PAINT AND GOT MY INFO FROM A LOCAL PAINT SUPPLIER. LOOKING FOR URETHANE THOSE WERE THE OPTIONS THAT I GOT FOR DUPONT PAINT. I THOUGHT IT WAS ODD THAT THERE WUOLD BE 2 DIFFERENT PAINTS. THE CODE 14 FROM DUPONT AND HAS WHITE PEARL MIXED IN.
THANKS, DON
87gn
009
307 walbor fuel pump
hot wire kit
3" down pipe
ported elbow
flow master
thrasher 93 street chip
adj. fuel reg.
adj. waste gate
scan master
Can this exact paint still be bought? Its exact codes I have
