VtheGNMan
- May 19, 2014
These aftermarket Fender Flares were modeled after the original GNX Fender Flares. These were originally purchased from Kirban Performance- a leader in quality aftermarket Grand National parts.
They were professionally painted gloss black and still look great after being run for only a short time.
No modifications have to be done to the car that would prohibit you from removing them at a later time if you choose to do so.
There is a thin rubber strip (welting) that runs along the edge of the flare where it is in contact with your paint so it will not rub and harm the paint.
These look great on a car that has wider wheels installed or the GNX rims.
They install just as your protective wheel well trim is installed, with small screws that go under the car inside the wheel well. When I removed my wheel well trim all the holes on these even lined up with the existing holes so I didn't have to drill any holes. Every car is a bit different though so can't promise you won't have to drill any holes.
There is one small screw hole that came in one of the flares for some reason when I bought them. It is on the drivers side front flare at the very bottom and is virtually unnoticeable once installed.
These are of much higher quality than the cheap fiberglass ones that are unpainted sold elsewhere here on ebay. The fiberglass ones take a lot of prep to be painted and do not have the welting along the edge either to protect your paint.
I am in Iowa, right outside Cedar Rapids if a pick up is desired let me know.
$300.00 + shipping.
Would consider trades.
PayPal preferred, add fees if not sent F&F.
$300.00 + shipping.
