Well I finally decided to replace my panhard bar since the rear end was wobbling back and forth making it a B**ch to drive. Bought a replacement bar and started taking the old one off and when I looked inside the bushings, I realized I had simply installed it wrong. (had it out for the fuel pump) The bolts only go in one way and the bar must be a U shape (not upside down) in order for the dimples in the sleeves to hit the larger diameter end of the bolt. Needless to say after realizing I screwed up, Ijust installed the original one correctly and now all is good and I saved some money.
