- Aug 20, 2001
I just happen to be zipping home on the highway tonight when i noticed when i par throttle the car, i would get a small amout of knock(>3%). What could be the cause of this? Could a correction be gapping the plugs tighter(mine are gapped at 35) or change the ones im running(ac43's)? Or maybe richin the mixture up a little bit? im running the 009's with the red93 chip, with the smc alky, along with all the typical bolt on's. I also have been getting some transition knock since running the alky kit, and wonder if the two could be related and maybe if i figured out how to correct one, it will correct the other.
Any advice would be appreciated. Keep in mind the im only getting very small amounts (>3 percent) but want to tune the car for street trim, with alky to run all through the gears with NO knock(maybe just a hair on the shift) which is normal.
Shoebox
Shoebox
