Roland Black
- Dec 20, 2001
I have a recent Art Carr 700R4 tranny and 9" TC (1300 miles ago). I went out driving today, and at first the Syclone was shifting normally under part throttle driving. All of a sudden, I had to get much higher in the mph and rpm before the tranny would shift. Example......... shifts to 2nd now around 25 mph and 4000 rpm, shifts to 3rd around 50+ mph and again high rpm. I didn't have enough room to try for 4th gear
TV cable adjustment didn't appear to make any difference, loose, tight or in between.
Weeks ago I removed the govenor and replaced the smaller weight to bring up the WOT shift point from 5000 to 5500. First try got me to 5450, and I decided that was close enough. When test driving the vehicle after this, part throttle was exactly as it was before the weight change..... yea!
As the govenor was the last thing touched, I removed it. All was intact (weights, springs). The center piston (doubtfull thats what it's called) was sluggish, so I cleaned the whole unit thoroughly with spray brake cleaner, and dried it. Once I was comfortable that it moved freely up and down, it was re-installed. On a test drive, I still must drive through local neighborhoods like a madman. I can see no difference.
I'm planning on pulling the govenor again, and trying a stiffer spring. Am I correct in my understanding that it is the spring connected to the heavy weight that I want to change for part throttle conditions?
Anyone have any ideas as to why the part throttle shift points suddenly changed? Thanks in advance,
