Part unknown: What is this and where does it go?
AJ_08
Hey guys,
Does anyone know what this is and where it goes? Asking for a 1987 GN. Thanks.
Tight fit up there. Does the hole in that panel match with a pin or something?
If I remember correctly remove the bottom plastic part around the ECM put the cap on and install
I think the ECM panels consist of 3 parts, and It seem I only have two, the main panel that the ECM sits inside, and this curved piece. Just can't seem to get it to sit properly.
There’s a little plastic “pin” that goes through the hole. It connects that piece to the kick panel. Then the two catches latch onto the thin plastic piece on the back of the ECM.
The piece you have goes on the top of the kick panel piece. There’s only two pieces. The piece you have & the kick panel the ECM sits in.
