parts for sale
TURBOKID
---Stage2 top end for sale all you need is a cam and short block! Heads are 1 1/2 years old and intake comes with everything you need to bolt on and run: Jesel rockers on heads plus 10 extra, Valve covers, 3 extra valves tit. intake and or Inconel ex.valves, 2 sets of valve springs, Push rods, and Isky roller lifters. Intake has TPS, IAC, IAS,CTS sensors,4 vacuum ports and temp gauge hole, 160lb injectors, fuel rails,elbow,90mm T-Body, about 2 or 3 sets of plugs and even intake and V/C gaskets. Heads are only a year and half old. Very nice RACE port work done.--$5800.
---MSD 7Al-2 Part #7226 have 2 of them--$300. each
---MSD Dist. set up for trigger. comes with spare cap, and rotor--Part #8551--$200.
---MSD Crank Trigger wheel and pick up Part#8630-$150.
---Weldon fuel pump Part#2025 and regulator #2040-$650.
---SX Fuel pump Part#18201-$200.
---Stock Block 109 .030 over $200.
---Stock Block 109 .030 with steel caps $250.
--- Stock cranks I have 2 .010 on both $250.each
---2 Stock intercoolers Offer?
---4 or 5 stock timing covers Offer?
---MSD DIS4 ignation boxes. One standard $200
---GT47/88 big Turbo 1 1/5 yrs old works fine and will make you haul ass $1500.
---12 stock rods for sale along with stock new pistons and 2 sets of .030 pistons TRW and ROSS
---5 Oncenter OLiver Wide rods with 5 JE coated 4.005 pistons $700.
--- Wiring interface harness for stock motor race harness $150
---Fast Race wiring harness that has been in my car over the last 5 years only what you need for fast system $300
I have pics that I can send
Day 919-274-4336
night 919-773-0494.
