TurboTA3.8
You wont keep up the pace
- May 24, 2001
Parts for sale
photos of some of the parts
TTA engine Fuel lines $60 "from rail to body"
tta oil cooler setup $80 "sold"
tta/gn cam sensor $45
tta/gn 200 mile coil pack and module setup with new gasket $150
tta motor mounts both sides right left engine and frame 1 frame mount need a small repair anyone with a drill and a welder can fix in 15min $150 "sold"
paxton automotive afpr for stock rail or 6an line $65
stock tta fuel rail $20
buick gn accel extreme heat plug wires one wite has a little burn can see in photo its only on surface $20
tta billet vac block $30
iac relocater block $45
new gm crancksensor and bracket $30
new gm tps 200miles $20
new gm iac 200miles $25
coolent pipe that runds from heater core to intake with t body lines closed off $25
tial 46mm wastegate with muffler and deltagate racegate-tial adapter flange so it will work with tial flange or racegate flange direct bolt on $340
fuel pressure guage $20
new gm knocksensor $20 only 2 dyno passes
crank pulley $20
lakewood rear lca for tta $50 "sold"
lakewood panhard rod adjustable $65
termostate housing and 180 degree termostate $15
tta alternator $50 new only 200miles
buick or tta assy bracket $65 includes 3 pieces 2 in the photo and a tensioner but it has been repaired ill just throw that in
all parts dont inc shipping
crank pulley $20
