20 bolt oil pan 140 engine code standard bore block with oil drain return punched in the front $100.00.
2 dot rods on stock bore turbo pistons $50.00.
8445 stock heads with fresh valve job, valve springs, rockers, & stock gn
valve covers (non ported) ran for less than 1000 miles with no smoking $150.00.
20/20 turbo crank $40.00.
Good used cam sensor $40.00.
Used front cover $20.00.
New set of 20 OEM stainless 86-87 t type/turbo t metric lugnuts $25.00.
87 stock radiator fan with oem delphi plug $30.00.
