Parts I need
87GNSteve
Just another pretty face....
Water heater lines (on intake)
Hard vacuum lines that go to top of throttle body(PCV FPR etc)
Brass turbo oil drain adapter
Turbo oil drain tube (stock)
Small brass oil fitting (in block)
Turbo oil feed tube (goes into above part)
Plate that goes under coil module
Upside down "U" bracket for coil
Water pump pulley
Oil and trans Dipsticks and tubes
Large (Y or triangle) accessory bracket that bolts to driver head
Well if you have any of this stuff and its not doing you any good and you want to get rid of it PM me.
But if you have this stuff and you tuck it into bed and kiss it good night, every night; I probably can't pay your price.:biggrin:
I will be listing more as needs arise.
I have the brass adapter for turbo oil drain tube as well as the tube itself (see picture) I'd like to get $50. for both...Let me know if interested...I might have the turbo oil feed tube and brass fitting, but I'd have to check to make sure.
Thank you,
Claude. :wink:
P.S: Price does not include shipping...Also, let me know about other stuff you might need as I have a box full of small TB parts...
I have a turbo feed line for $20 shipped to ya.I can post a picture tomorrow for you if interested.
Steve, I have the "Turbo "oil drain tube", but just found out that I also have the "Turbo oil feed tube"...I PM'ed you about it...
Thanks,
Claude. :wink:
