jwillettgn
- Feb 8, 2006
This is a post where you can list parts you can bring to Reynolds.
We have several parts we can bring if someone needs them.
1. 200R4 BQ trans from our 85 GN, worked when we pulled it, went to a T400
2. D5 converter from the above car.
3. 8.5 rear, open, from above car, no brakes, went to a 9"
4. Stock intercooler modded to have 3" straight inlet and outlet ( from Turbomotion V2 kit)
5. 86/87 main accessory bracket.
6. Upper A arms with new urethane bushings and new ball joints, never installed. Had all new parts installed then went to tube A arms.
7. New never used Red's Hot Air 93 Chip for stock injectors.
8. New never used MMC Hot Air chip for MSD 50 lb. injectors.
9. Stock GN driveshaft.
10. Fully dressed Hot Air intake.
11. Hot Air Turbo to intake adaptor
12. Hot Air TB
13. Hot Air MAF
14. 86/87 Valve covers
15. 84/85 Valve Covers
16. Gas Tank out of the 85 GN with a new never run 340 Pump installed. We installed a fuel cell.
17. Hot wire kit for an 84/85 Turbo Buick
18. Caspers MAT kit for converting 84/85 to an 86/87 ECM New, never installed.
19. ARP Head bolts 223-3701, engine builder started to install them then said they were the wrong ones for our block.
20. Stock hot air headers, cross over, and up pipe, need welding.
21. 85 ECM
22. 85 Ignition Module/coilpak.
I really don't have time to ship parts as I work so much, hunt too much, mess with Jeeps, and trying to get this GN running finally. LOL
Jim
12. Hot Air TB
13. Hot Air MAF
21. 85 ECM
Jim
