parts
50 lbs. injectors 6 each 300.00
70mm TB w/angle IAC 300.00
AC Accm 25.00
AC Condenser 100.00
AC Hose Set 50.00
AC Pump 200.00
Adj. fuel pressure billet 85.00
ground extender kit 35.00
ANS Knock - Knock sensor (in-car)Audible & Visual 15.00
Anti-Rattle Kit (Door) (2) Both for 50.00
A-Pillar Gauge Holder (1) 15.00
ATM 2663 Auto-Meter Fuel Pressure Gauge - Electronic in-car 125.00
Big Mouth Ram Air - Power coated 110.00
Boost Valve (switch) 15.00
Brake Accumulator. Used 1 time 50.00
Caliper Bracket (98 camaro) 30.00
CAM Sensor Tool 20.00
Door outer seals 70.00
egt gauage omega hh 11 w/ adp. 140.00
Egr Block off plate 10.00
Emblem "Inter-Cooled" Both for 15.00
fan relay cover lef side 10.00
Fender Emblem "Grand National" (2) Both for 25.00
Fuel tank sender w/pump stock (New) 70.00
Heated 02 Kit 80.00
Hi fan relay 10.00
Left bumper extension rear (New) 150.00
LS1 MAF w/hose 75.00
Rear Main seal 8.00
RGC Power Plate 48.00
THDP w/cat 345.00
Top radiator hose - metal G body parts 100.00
torque converter precision ind. Lock up 3200 stall 700.00
Torque Strap 25.00
Trans Plus 250.00
TE-60 TURBO W/ H.D. ACTUATOR $500.00
Upper PLM 70mm 100.00
Volt Booster 45.00
That is Duane's list. I am just posting it for him. Please contact him for anything else!
Thanks!
If the emblems are in really good shape, I want em.
Are the rattle elimination kits, the ones from Kirbans? If it's $50 for both doors, I'd like those too.
Is the Big mouth for a stock maf or later model maf? Is it steel or aluminum and what powder coat is it, back or silver? Filtet included right?
Thanks.
