Oct 20, 2014 #1 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 hi this is maybe an easy one but can't get it to stay in the housing.it popes out when i snap the clip in to give it tenyion anyone have this problem .thanks for shimming in .in advance .
Oct 20, 2014 #2 8 87geeinn Buick and AMG pilot Joined Jan 17, 2006 Messages 1,339 Just buy a new wiper
Oct 20, 2014 #3 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 its not the blade its the arm .it keeps popping out from the pivot arm the slide clip is not holding it in place .
Oct 20, 2014 #4 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,996 Look inside the arm, if it's all chewed up and the ribs are gone you need a new one. Same with the fixed mount part, white metal, if it's chewed up you need to replace that part which isn't easy. I just drilled and tapped a couple of 4-40 or #6 (don't remember) screws in mine with loctite.
Oct 21, 2014 #5 B bpman1234 Well-Known Member Joined Jan 24, 2011 Messages 2,001 salvage v6 yep that's what it is thanks for your reply have a great day. Posted from the TurboBuick.Com mobile app
Oct 22, 2014 #6 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,996 I tried some shims to take up the slack, thin brass, that may work short term, but not in the winter snow and ice. Space age epoxies didn't work either too much side force on it I guess.
