pcv intake grommet.
SS_Sean
Pro Bracket
Anyone have a secret to getting a new pcv intake grommet in short of taking the intake off. It ain't fun and it ain't easy. I've tried lythium grease and screw drivers to pry it in, but I'm running out of options. :mad:
Got 'er in. Tried dishsoap, tried lythium grease and silicone spray ended up working. Just worked it in using two screwdrivers. Also sprayed the pcv valve grommet with silicone spray again and then used a socket and extension to 'press' the pcv valve into the grommet. That was a sucky sucky fix, but no more vacuum leaks. :)
