I like the look of the vacuum block of plates. Everything is easy except the PCV routing. I like to hide it. I have drilled and taped the back of the twice but it's an awkward line route. Thinking about blocking the original pcv hole and welding an AN fitting under the coil pack area with a pcv valve in line....
What are you guys doing with the PCV when using the vacuum block off plates.
