Physics question.. can you figure it out?
Kevin please list all buildings you have had input on there designs. These will go onto my "do not enter list"
I'll stick with my 6 years of art school and endless hours of coloring to say that the plane does fly! ;)
Ok the conveyer is 100 yards long. the plane is setting at the 50 yard line. The plane powers up and starts moving forward (right) at 1mph. The conveyer tracks that speed and starts moving left at 1mph. As the plane continues to pick up speed and move towards the 45 yard line, the conveyer picks up speed at the same rate. By the time the plane hits the goal line it is doing 70mph and the conveyer is doing 70 mph in the opposite direction. The plane takes off from the goal line, not from the 50 yard line where it started.
We have runways cuz the plane has to have forward motion to take off, obviously you know that. The fact that this is a moving runway makes no difference.
Take it in a different direction. Lets say that the plane and the runway are moving in the same direction and there was zero drag from the wheels. If the conveyer is moving at 70mph and the plane slowly puts on the breaks the conveyer would accelerate the plane up to 70 mph and it would take off. If the plane left the brakes off and instead used the prop to accellerate it up to 70 mph it would actually take off with zero tire speed.
clear as mud?? :D
..and I'm standing on the ground next to the plane/conveyor and if the belt matches the speed of the plane in the opposite direction then the plane doesn't move away from me.. It stays put.
Correct?
ks:)
Correct?
ks:)
Incorrect... if the belt moves away from you at 60 mph and the plane stays right beside you that violates the parameters of the problem as stated.
Let's look at it from another direction. If your standing beside the belt.. how fast is it moving away from you? the plane will be moving away from you in the opposite direction at the same speed.
V6 Beast said:
Incorrect... if the belt moves away from you at 60 mph and the planes stays right beside you that violates the parameters of the problem as stated.
I GET IT!
THNX! You're right!
I was reading it wrong.. I thought the conveyor was "maintaining" 0 velocity for the plane relative to me standing next to the belt but it's not!
ks
V6 Beast said:
Well if it's not moving forward relative to the ground then the conveyer isn't moving.
Think of it like this. When you use your line lock, lock your front tires, do a burnout and your speedo says 100 mph is there anyway that you could say the car is going 100 mph? Relative to anything?
No of course not.. you know that car is moving no where. Well that is what you non-flyers are trying to say. A plane sitting there spinning it wheels at 100 mph would cause that the conveyer is going to move at 100 in opposite direction. Now that is what violates the definition of the same.
The conveyer moves at the same speed as the plane moves. Sitting in the same spot is not moving. The plane and the conveyer have to use the same point of reference to determine their speed. You can not use the conveyer for the planes point of refererance and the ground for the conveyers.
I guess I was able to make it more clear afterall....
I see your point, the airplane speed and treadmill speed must both be relative to the ground... so the airplane is effectively doubling it's treadmill speed (compared to groundspeed) and will shoot down the treadmill-runway and fly.
I was assuming the plane was staying stationary compared to a fixed object on the earth like a tree, but that is not the case :D Doh!
Pete
this kept me up last night, and heres what i came to.
it all depends on the plane. suppose it has amazingly effecient bearings. and its setting on the convayer (everything is still) then the convayer starts. due to the inirtia ove the plane and its impossibly effecient bearings the plane will sit perfectly still relative to the ground. when power is applied it will move just as it normally would and the convayer would make absolutely no difference no matter how fast it was moving. it would be exactly the same as normal.
Now in a more realistic situation you have a 50 year old plane with wheel bearings that are something like 80 years old (fly an old cessna, you'll understand) and the wheel bearings are shot, when the convayer starts you mine as well have the brakes on, and the whole plane will move backwards untill power is applied. then its a matter of how much power do youhave, how much drag is there, and how fast is the convayer pushing you backwards. it may or may not fly depending on those variables.
i'm going to go read the 2 newest pages now, hopefully i didnt' repeat anything anyone else has said.
Geez... I asked my wife about this a second ago just out of curiosity and without hesitation she replied the plane would fly because the wheels would free wheel and the plane would move forward....and no six years of engineering.... :biggrin:
You are correct though sir.... the condition of the wheel bearings would have affect... as would the weather ... how much fuel was in the plane..... air pressure in the tires ...oil pressure in the engines... etc. etc... The poster of the original question should have been much much clearer on the condition of the plane... :rolleyes:
TType84 said:
A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in opposite direction).
The question is:
Will the plane take off or not? Will it be able to run up and take off?
this is very simple.. do not overcomplicate it.
what do you think tb.com?
Of course as soon as I sent the orig post I finally got it. It will take off :smile:
The question is totally flawed. A plane going down the runway needs a certain speed to attain lift> It clearly states that the conveyor matches the PLANES speed, not the speed of the tires. Anyone that has put bigger wheels on a car knows you have to recalibrate the speedometer. The answer to the question is that the plane will not move an inch and goes nowhere. If you say that the conveyor matches the planes TIRE speed, that would be a different question. Put a radar gun when you are matching the planes speed and it will be "0" mph. It would also be different if the plane already had foreward progress. Take the same treadmill example but put rollerskates on the peron. Have them rollerskate down a hill and jump on a treadmill set at the same speed as the rollerskates wheels and it will still skate right over and past the treadmill.
JMHO
Oh No .... not again... THE... SPEED.... OF.... THE.... CONVEYOR....MAKES....NO.....DIFFERENCE.....
In theory, the same would apply to a car, but using a reference point off the conveyor belt. Say that you are using a radar gun to track the car's speed on the conveyor, not the car's speedometer. If the car was moving 70 mph forward (as indicated on the radar gun), the belt would be moving 70 mph in reverse (compared to a stationary point off the belt), but the speedometer on the car would read 140mph. Once you consider that you need one outside reference point to determine the relative speeds of both the plane (or car) and the belt, it makes sense.
So those that said the car would just sit there and spin its tires stationary, this would only be true if you are using the cars speedometer as the reference, not a point off the belt as a reference. If you are gunning a car from a stop, get to 70 mph and hit a patch of ice, you are still going 70, even though the slipping tires say you are going much faster, correct? This negates the whole "thrust" is different because its pushing on air argument. A car will move just as easily as the plane, if the calculated speed is measured by a radar gun off the belt.
It all depends on your method of "speed" calculation.
i think you've got it right. in a perfect situation it would fly, i think most anyone will agree to that. in pratice, its a toss up. do it in a lancair or something god awfull over powered and with good quality parts and it will surely fly. get a 747 and by the time the engines spool and over come the friction of the 18 something huge tires and all its mass and it will be shot off the end of the convayer before it ever had a chance. Its really an unanswerable question with the information given. thats probably why its such a thinker.
Not quite right. The car derives it's forward motion by pushing off against the surface it sits which is the conveyor. That negates the tire's forces.
An aircraft uses AIR to force itself forward which has NOTHING to do with the surface it's resting on, regardless if it's a moving conveyor or stationary runway.
final answer from me, here goes:
Strap a jetpack to your back, then get on a log in the lake.
Now start running. Soon you're running about 12 mph, but you're not moving because the log is matching your speed.
Now fire up the jetpack.
Now, if someone can logically explain how the log spinning under your feet is going to keep you from flying away, I'll believe the plane on the conveyor won't move either!
This is from board member FlightTest
F/A-22 Flight Test Engineer
Lockheed Martin
The Pilot's Lounge #94: It's The Medium, Manfred
There's a new aviation myth running around the Internet. It involves a conveyer-belt runway and misuse of aerodynamics and ... well, it's better if AVweb's Rick Durden explains it all himself in The Pilot's Lounge.
By Rick Durden
Columnist
I heard the commotion as I started down the hall from the flight school to the Pilot's Lounge at the virtual airport. In the few moments it took to get to the door of the Lounge, individual voices became clear, split into two very vocal camps: The vehement "Yes it will!" calls being answered by an equally intense "No it won't!" I thought back to some of the stronger disagreements that had been aired here, such as the use of flaps on landing, but this one seemed a little louder and I wondered whether Old Hack and some of the bigger guys might have to separate combatants.
I stood off to the side and tried to get a handle on the conflict. Old Hack saw me and sidled over with a silly grin on his face. "These guys spend way too much time on the Internet," he said. "Someone has just come up with what looks like a 21st-century version of the old "downwind turn" foolishness and now the engineers and the soft-science folks are having at it."
The "Fatal" Downwind Turn
For those who don't recall the "downwind turn" tale of the last century, it goes like this: People observed that pilots who were flying relatively low on a heading that took them into the wind had a surprisingly high rate of impact with the ground or obstructions if they rolled into a turn and proceeded to a heading that was with the wind direction, or downwind. There were those who insisted that the airplane could not accelerate fast enough in the turn to make the necessary groundspeed change so as to stay above stall speed and thus they crashed.
As an example, we'll take a pilot with a reputation for good stick and rudder skills, a certain Manfred. We'll magically reincarnate him from the Western Front of World War I (where he had perished) and put him in a 65-hp, Piper J-3 Cub. Its cruise speed is pretty close to the Fokker Dr-I that Manfred last flew -- call it 80 mph. (The Fokker Triplane was so maneuverable few enemy pilots ever figured out it was astonishingly slow.)
We'll point Manfred and the J-3 northbound at 500 feet AGL into the teeth of a 40-mph headwind. His groundspeed is, therefore, 40 mph. Now we'll have him roll into a turn and change directions 180 degrees until he is headed south, directly downwind. We'll have him make the turn in 30 seconds, a twice-standard-rate turn. At that airspeed, it's not very steep and certainly not at all unsafe. The next consideration is that in those 30 seconds, Manfred's J-3 has to accelerate from a groundspeed of 40 mph to a groundspeed of 120 mph in order to still be moving through the air at 80 mph. In fact, if he does not accelerate through that needed 80 mph change in groundspeed, the airplane could stall because the airspeed would have dropped off radically.
There were those who were convinced that it was impossible for a 65 hp J-3 to increase its groundspeed by 80 mph in 30 seconds, and therefore the airplane would stall, which was what made downwind turns so dangerous.
Fortunately, back when this was being debated, rationality prevailed. It was pointed out that the airplane was flying through the air, its propeller was acting upon the air and its wings were moving in an airmass. Thus, when it made its turn, its airspeed didn't change. The airplane continued to move through the air at 80 mph. Its groundspeed changed solely because of the fact that the mass of air in which it was operating, the medium upon which it was acting, was moving.
Had the air been calm, Manfred and his J-3 would have had a groundspeed that matched his airspeed.
Interestingly enough, when the famous aviator, Jimmy Doolittle was sent by the Army to M.I.T. to study in the mid-1920s, his dissertation for his Ph.D. included some of this discussion, so the problem's been solved for some time; it just took most of the rest of the century for the understanding to trickle down. (Yeah, that air-racing, aerobatic, military pilot also had one of the first Ph.D.s awarded in aeronautical engineering.) Doolittle also hypothesized that the frequency of crashes during such turns was the visual effect of the rapidly increasing groundspeed causing pilots to believe that the airplane was suddenly going very fast and pulling back on the stick or throttle, leading to a stall or descent into the ground.
For those who still didn't understand that the downwind turn had no effect on the airplane, all it took was a flight on a day with some wind above a solid deck of clouds. Making a few circles made it clear that the airplane and its pilot could not tell anything about the direction of the wind while turning.
Conveyer-Belt Runway
What I learned from Old Hack was that an updated version of a question aimed at confusing folks over relative measurements of airplane motion and the medium in which it operates had shown up on the Internet, and it was causing the fracas in the Lounge.
The question that has been going around is not particularly artfully worded, and I think that has caused some of the disagreements, but I'll repeat it as it is shown: "On a day with absolutely calm wind, a plane is standing on a runway that can move (some sort of band conveyor). The plane moves in one direction, while the conveyor moves in the opposite direction. The conveyor has a control system that tracks the plane speed and tunes the speed of the conveyor to be exactly the same (but in the opposite direction). Can the airplane ever take off?"
My comment: Notice that the question does not state that the conveyor's movement keeps the airplane over the starting position relative to the ground, just that it moves in the direction opposite to any movement of the airplane.
Initially, about a third of the folks here said that the airplane could not ever takeoff, because the conveyor would overcome the speed of the airplane and it could never get any airspeed. The rest said the airplane would fly.
The "It won't fly, Rocky" group said that the conveyor would hold back the airplane. They asked us to imagine a person running on a treadmill. As he or she sped up, the treadmill would be programmed to speed up, just as the conveyor in the problem, and the person would remain over the same locus on the earth, while running as fast as possible.
The argument was that if the airplane started to move forward, the conveyor program was set up to move the conveyor at exactly that speed, in the opposite direction, thus, the airplane would never move relative to the ground, and, because the air was calm, it could never get any wind over its wings. One of the analogies presented was the person rowing at three mph upstream in a river on a calm day. However, the current was flowing downstream at three mph, so the resultant speed with reference to the stream bank and air was zero, and thus there was no wind on the rowboat.
I watched and listened to the disagreement for a while and was fascinated to see that the argument seemed to split between those who had some engineering or math background, all of whom said the airplane would takeoff and fly without any problem; and those with some other background, who visualized the airplane as having to push against the conveyor in order to gain speed. Because the conveyor equaled the airplane's push against the conveyor, the airplane stayed in one place over the ground and in the calm air could not get any airspeed and fly.
It was an interesting argument, but as things progressed, more rational heads prevailed, pointing out that the airplanes do not apply their thrust via their wheels, so the conveyor belt is irrelevant to whether the airplane will takeoff. One guy even got one of those rubber band powered wood and plastic airplane that sell for about a buck, put it on the treadmill someone foolishly donated to the Lounge years ago, thinking that pilots might actually exercise. He wound up the rubber band, set the treadmill to be level, and at its highest speed. Then he simultaneously set the airplane on the treadmill and let the prop start to turn. It took off without moving the slightest bit backwards.
Manfred In The 21st Century
OK, let's figure out why the airplane will fly.
We'll use Manfred again. Although we're bringing him forward into the 21st Century, we'll still let him use the 65 hp J-3. It doesn't really matter what airplane he flies, but he got used to the J-3 while he was demonstrating downwind turns and this one happens to have lifting rings on the top of the fuselage. It's also been modified with a starter so no one has to swing the prop.
Manfred's in the airplane. Old Hack has the Army-surplus crane fired up and he's picking up the J-3 and Manfred and carrying them over to Runway 27, which has been transformed into a 3,000-foot conveyor belt. It is a calm day. The conveyor drive is programmed so that if Manfred can start to move in the J-3, if he can generate any airspeed or groundspeed, the conveyor will move toward the east (remember Manfred and the J-3 are facing west) at exactly the speed of the air/groundspeed. Because the wind is calm, if Manfred can generate any indicated airspeed, he will also be generating precisely the same groundspeed. Groundspeed, of course being relative to the ground of the airport surrounding the conveyor belt runway. So, the speed of the conveyor belt eastbound will be the same as Manfred's indicated airspeed, westbound.
Manfred does his prestart checklist, holds the heel brakes, hits the starter and the little Continental up front clatters to life. Oil pressure comes up and stabilizes and Manfred tries to look busy because the eyes of the world are upon him, but all he can do is make sure the fuel is on and the altimeter and trim are set, then do a quick runup to check the mags and the carb heat. He moves the controls through their full travel and glares at the ailerons, doing his best to look heroic, then holds the stick aft in the slipstream to pin the tail and lets go of the brakes.
Baron of the Belt
So far the J-3 has not moved, nor has the conveyor. At idle power, there's not enough thrust to move the J-3 forward on a level surface, so Manfred starts to bring up the power, intending to take off. The propeller rpm increases and the prop shoves air aft, as it does on every takeoff, causing the airplane to move forward through the air, and as a consequence, forward with regard to the ground. Simultaneously the conveyor creaks to life, moving east, under the tires of the J-3. As the J-3 thrusts its way through the air, driven by its propeller, the airspeed indicator comes off the peg at about 10 mph. At that moment the conveyor is moving at 10 mph to the east and the tires are whirling around at 20 mph because the prop has pulled it to an airspeed, and groundspeed, of 10 mph, westbound. The airplane is moving relative to the still air and the ground at 10 mph, but with regard to the conveyor, which is going the other way at 10 mph, the relative speed is 20 mph.
Manfred relaxes a bit because the conveyor cannot stop him from moving forward. There is nothing on the airplane that pushes against the ground or the conveyor in order for it to accelerate; as Karen -- one of our techies here at the Lounge -- put it, the airplane freewheels. In technical terms, there is some bearing drag on the wheels, but it's under 40 pounds, and the engine has overcome that for years; plus the drag doesn't increase significantly as the wheel speed increases. Unless Manfred applies the brakes, the conveyor cannot affect the rate at which the airplane accelerates.
A few moments later, the roaring Continental, spinning that wooden Sensenich prop, has accelerated the J-3 and Manfred to 25 mph indicated airspeed. He and the airplane are cruising past the cheering spectators at 25 mph, while the conveyor has accelerated to 25 mph eastbound, yet it still has no way of stopping the airplane's movement through the air. The wheels are spinning at 50 mph, so the noise level is a little high, but otherwise, the J-3 is making a normal, calm-wind takeoff.
As the indicated airspeed passes 45 mph, groundspeed -- you know, relative to where all those spectators are standing beside the conveyor belt -- is also 45 mph. (At least that's what it says on Manfred's GPS. Being brought back to life seemed to create an insatiable desire for electronic stuff.) The conveyor is also at 45 mph, and the wheels are whizzing around at 90 -- the groundspeed plus the speed of the conveyor in the opposite direction.
Manfred breaks ground, climbs a few hundred feet, then makes a low pass to see if he can terrify the spectators because they are Americans, descendants of those who defeated his countrymen back in 1918.
It's All About Airspeed
While the speed of the conveyor belt in the opposite direction is superficially attractive in saying the airplane cannot accelerate, it truly is irrelevant to what is happening with the airplane, because the medium on which it is acting is the air. The only time it could be a problem is if the wheel speed got so high that the tires blew out.
Put another way, consider the problem with the J-3 mounted on a hovercraft body (yes, similar things were tried about 30 years ago). The hovercraft lifts the airplane a fraction of an inch above the conveyor belt, and so no matter how fast the conveyor spins, it cannot prevent the propeller -- acting on the air -- from accelerating the airplane to takeoff speed. It's the same with wheels rolling on the conveyor belt. Those wheels are not powered and thus do not push against the belt to accelerate the airplane. Were that the case, the vehicle could not reach an airspeed needed to fly, because then the conveyor, the medium acted upon by the propulsive force, would be able to negate the acceleration relative to the air and ground.
I'm reminded of the New York Times editorial when Robert Goddard's rocket experiments were first being publicized. The author of the editorial said that rockets can't work in space because they have nothing to push against. It was laughably wrong, ignoring one of Sir Isaac's laws of physics that for every action there is an equal and opposite reaction. Here the propeller is pushing against the air, as it does every time an airplane takes off. How fast the airplane is moving over the surface on which its wheels rest is irrelevant; the medium is the magic. On a normal takeoff -- no conveyor involved -- if there is a 20 mph headwind, Manfred and the J-3 will lift off at 45 mph indicated airspeed; but relative to the ground, it is only 25 mph. Should the wind increase to 45 mph and if Manfred can get to the runway, he can take off without rolling an inch. His airspeed is 45 and groundspeed is zero. It is not necessary to have any groundspeed to fly, just airspeed. Conversely, if Manfred has a lot of runway and nothing to hit, and takes off downwind in a 25 mph tailwind, the propeller will have to accelerate the airplane to a zero airspeed, which will be a 25 mph groundspeed, and then on to a 45 mph airspeed, which will have him humming across the ground at 70 mph. The speed over the ground, or a conveyor belt, when an airplane takes off is irrelevant; all that matters is its speed through the air, and unless the pilot sets the brakes, a moving conveyor belt -- under the freely turning wheels -- cannot stop the process of acceleration.
Things eventually calmed down as the number of "it won't fly" folks dwindled as they began to understand that the airplane would take off. Old Hack looked at me and suggested we depart as the few holdouts showed no sign of changing their position. So, we headed out into the night to watch the guys take the conveyor out and reinstall the runway.
This is amazing that so many cant see that the plane will fly? If the jet engines were fired up sitting 20 ft above the conveyer belt like they are on the plane what would they do? They will accelerate down the runway oblivious to the conveyer belt on the ground. Now if you hook the plane to the engines like they all are, what will the plane do? It will follow the engines down the runway unless you assume that because the conveyer belt is moving in the opposite directions the plane will just sit there and the engines will rip themsleves from the wings and go on without the plane lmao
