Pick my turbo!!
ecmo92
What do you guys think would be the best street/strip turbo with my combo? I will be doing the Dutt neck and either the alky or the propane. Thanks!!:p
price?
Whats the price for the John Craig turbo? Same as PTE? Whats the diffs? What makes his turbos so good? If the price is good and its as good as whats been hinted at I'll probable get one!! :p
You have pretty much a 10 second combo there. I'd go TE-45 or TE-63E with a good 3,200-3,500 stall, 55 lb injectors, V4 IC, modded ECM, updated chips, and double pumper if it was me.
Otherwise I would start out with least a good 'ole TA or TE-61 that would work without the other stuff I listed above.
TE-44/TA-49 would work well too but I think you will out grow pretty quickly.
As mentioned above a good ol TA 49 or TE 44 will be a good turbo for that combo. The limit there is the converter. With a bit more stall a 61 would be good or a TE45 .
My motor is very similar to yours. I called J. Cotton and he recommended his CPT 60.
