Apr 4, 2017 #1 T TOOMANYTOYS Member Joined Oct 18, 2003 Messages 229 does anyone know what size the pitman arm nut is?
Apr 4, 2017 #3 T TOOMANYTOYS Member Joined Oct 18, 2003 Messages 229 I tired that size and it was loose. I was afraid I would strip the nut if I used it
Apr 4, 2017 #4 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 I have used a 1-3/8" socket to remove that nut, and it is a rather loose fit, the 1-5/16" should work ok. The nut measures to be 33mm to be exact. When the going gets real tuff, I rely on my one and a half foot long Crescent wrench, and a helper!
Apr 5, 2017 #5 T TOOMANYTOYS Member Joined Oct 18, 2003 Messages 229 Well I ended up using a 1 5/16. It was a little loose but the nut came off. Getting the arm off the steering box turned out to be a lot harder than I thought
