PL and SM question
Brad_H
So I purchased a scan master and a power logger...the power logger came with a 2.2 upraised forties can master...my question is that I haven't installed either yet do to resto in progress, but should I install the 2.2 chip in the scan master right away or should I install it first with 2.1 then switch it to the 2.2?
You don't need to install the 2.2 chip until you get ready to install the Powerlogger.
Ok we'll first my car has the stock 84 ecm in it.....second I bought a 86/87 ecm and cal pac from 1987GNASTROROOF.......now I'm installing the power logger.....I have never tried the scan master (only a few weeks old) and was wondering if I can go ahead and switch it to the 2.2 and then install it to my computer and car and just put away the original 2.1 or do I have to install the 2.1 first then take it apart and install the 2.2
2.2 only works with a powerlogger hooked up to your computer to the analog block , 2.1 only with works without the powerlogger in the stock diagnostic block .
So your saying with the 2.2 when hooked up to the power logger only works with a lab top.....I was hoping to still read engine data without the computer just off the scan master
I'm a little confused :0
Yes it will work without a laptop
Ty.....installed power logger to my 86/87 ecm and put the 2.2 chip in the scan master...just need to get a wb....is there a wb with boost as well as a/f
