For the past several months since the GS Nationals I have been having problems with getting stranded after 15-20 highway miles. So now I am in process of replacing the crank sensor and found that the balancer bolt was loose.
After removing the belt I grabbed the pully to turn the engine and discovered I could turn the assy left / right just a little bit. The balancer is not cracked and the keyway is not chewed up. looking into the front cover the key appears to be square, not chewed or chipped and is tight in the crank. I didn't try to remove it since it was tight There is no balancer 'wobble' on the shaft and the fit is good . BUT I can turn the pully just a little bit like a click-click movement,maybe a 64th of an inch or less side to side.
Is this normal tolerance or should there be 0 tolerance just pull off staight on with no turn tolerance. I thought it strange that the bolt was only snug not tight.
The loose bolt may allow the movement as I drive causing my strange firing issue. It drives fine for a while then acts up (spits, bucks, backfires, dies) after continuous driving for 20 or so miles on the highway. After cool down it starts and drives fine, for a while.
Would a little bit of tolerance at 2500 rpm cause timing issues if the pulley is moving that way? The crank sendor was not chewed up so I don't think there was any in-out tolerance. the crank nose also looks good, not worn.
Suggestions? Just tighten the bolt down as this is normal tolerance? Replace the balancer and or the key to get rid of any twisting movement?
