Please Delete... Thank You!
StageIIGN's
Hello,
I know I'm not suppose to post parts wanted here. But, I wasn't getting any replies in the parts wanted section. My preference would be in this order 017, 016, then 012. If you have a 153 block I may consider that as well. I would also prefer a block that has four bolt caps. I may also be interested in a short block or complete motor. I'm not interested in an all out race motor.
Thanks! Good luck to you as well! It's not a huge deal for me anyway. If I don't find one soon, I'll just buy another TA block...
I misread the post, I thought it said the block was .060" over. I could tell from the pic that the cylinder walls were very thin!
Thanks again for sending the link...
I have one that needs to be bore honed stage 1/ #12 New Parts that come with this bare block. Steel caps , white racing blue printed timing cover and external pump , RJC oil deep sump pan with welded provision ,
It's @ 30' over once honed and cleaned up.
Has a small hair line crack that was repaired on the valley area, welded and stitched up. Pressure tested and x ray and it is
Good.
I'll take $2000
