Please help ID these chips please!
Adam Connell
Monster Truckin since 87'
Ok, I got a ton of stuff with my car and Im finding new stuff every day... so today I find this altoids can and it has two chips in it... one of them has "JC STOCK" hand written on it with "MALAYSIA" on the bottom. The other has "ACXA 0942" on the top, and "JT8(G)AA29/P" on the underside.
Any idea what chips these are? Also, if I knew where my ECU was and how to remove the chip I would ask what it was, but I have not gotten that far into the car hahaha.
I can't help you out with the chip ID's but your cars ECM is in the kick panel of the passenger side compartment. You just unscrew it and the ECM pops out. The chip will be in the lower left hand side I believe. You simply pull the chip out in order to swap chips etc. Now be advised, unpluging the chip or battery may erases settings on the current chip depending on the chip manufacture etc.
I would say the JC stock is a Jay Carter chip for stock injectors, The ACXA chip is a stock GN chip, and the last one might be a Jim Testa chip.
