Originally posted by new2boost
Hope someone can help me...just bought a 85 gn it was not running and had the front timing cover off. I replaced the following:Timing belt,o2 sensor,knock sensor,fuelpump,spark pack,new wires,new plugs,. Okay here is what it does ...it starts and idles fine it, is just a dog, no power when I give it throttle it just lays down ....also the manifolds on this will glow cherry red when under a load. The scan tool gives a code that the spark timining sensor is bad ...but I repalced the spark knock sensor and no change same code same problem...please help.. also the previous owner had a adjustable wastegate on this ...should I put the stock one back on? Does anyone have a diagram for the vacum lines on this car as the previous owner was a real gem and has all kinds of the hacked and plugged... tonyalester@earthlink.net
Sounds like you may have a plugged up exhaust, is there catalytic converter on there now? If so it may be clogged up.
Vacuum lines go like this on hot air,
Vacuum block has six ports,
FRONT FAR LEFT PORT goes to PVC Valve with a tee to the wasgate solenoid plumb back Vent.
MIDDLE FRONT PORT of vac block goes to Charcoal canister
RIGHT FRONT PORT goes to the big port on the EGR vacuum regulator solenoid.
LEFT REAR port is Plugged off if you have hydra-boost Brakes, if you have vacuum power brakes then it goes to it.
MIDDLE REAR PORT goes to lower wastegate actuator port as a (" part throtle open waste gate") to improve off boost fuel economy by reducing exhasust back pressure
RIGHT REAR PORT goes to HVAC CRUISE VACUUM CANSITER AND THERE IS A CHECK VALVE THERE
Pressure port on compressor side of turbocharger feeds the top port on the wastegate actuator through a restrictor oraffice and also tee off into the wastegate solenoid port.
Manifold VAC/pressure tap on the rear of the intake manifold feeds the fuel pressure regulator and boost gauge sensor, a 2 stage (YELLOW/ORANGE switch if you have digital dash or map sensor if you have bar graph boost guage of the analog dash.
GOOD LUCK
