Please Help Start This Car
slamming 6
Drag Master
Just put the motor in and now it will not start(87 GN) it sound like the injectors are spraying when the fuel pump runs.key on fuel pump cycles I can hear them spray,crank it over fuel pump runs and they spray.Aeroflow pump run through a 30amp relay i have fuel pressure until it stops after it cycles and when i crank it but as soon as it stops the pressure drop's. used a mechanical gauge on the fuel rail.TIA AL.
slamming 6 said:
where is the check valve,how do i checkout the regulator.TIA
Are you using the factory lines at all? If you are then the regulator should be in the normal location on the fuel rail. You may run into problems of the return line not being large enough to control.
Intercooler I know where the regulator is how do i check it out,fuel line is a -10 and the return line is -6.
