I just checked a couple plugs today, being unsure of their condition since they were in the car when I purchased it. (Only fooled with the easy-to-get-to ones up front for the time being.) Currently, I'm running Autolite 24's and they're quite white. Appears to be a little too hot.
The car is basically running a stock setup, and I've only hit about 15-17 psi of boost max. I checked the gaps, and it was way out of wack. Was gapped at about .042, which I'd like to believe was a mistake, and I'm going to correct it with the new set of plugs to a .035 gap.
Any reccomendations? I was thinking of stepping down to Autolite 23's, (and make that platinums too). Should I run a little cooler? If I'm not mistaken, the heat range of the 23's is the same as AC CR42TS, which folks usually recommend for higher boost or sub-12 second cars. And thats not quite my ET (yet). Since the 24's would then be equal to AC 43's, I would assume the same results as with my current autolites. I may just use AC plugs, but which heat range? And could the fact that they're over-gapped be causing it to burn too hot?
