PM Problem
Art-87TR
231 + 455 = Perfection
Just noticed every time I hit the brakes the Motor runs. (red light does not come on). Turn it off, pump it down (it takes 14 pumps Not 10) - turn it on 14-15 sec. pump stops. Let it sit 5 minutes no cycle. When I opened top after pump dowm very foamy - cleared in bout 3-5 minutes. I did this several times with no change, soon as I hit the brake the motor runs. This is one of the Kirban lifetime units I bought about 5 years ago but literally no miles on it.
Air=Foam. Possibly just a little low on fluid. With the key off, pump the system down. Let the foam settle then top off the passenger side of the reservoir.
Hope that helps.
Hope that helps.
First thing I did, Didn't help.
Any signs of a leaks around the pm area? How's the hose from the reservoir to the pump? Check the hose clamps?
Time to do a vac conversion. When I had pm's in my gn none lasted longer the 5 years. Convert and save your life and your money. You won't regret it.
