- Dec 15, 2002
SignUp Now!These might be cool if you are looking for an aggressive look,
Centerline Daggers.
I ended up purchasing some 19" Axis Pentas to be unique.
I also have my welds with M/T drag radials for the track.
What percent tint do you have (off topic, but I'm the original poster MWAHAHAHHA)
I meant to comment on PsYcHo GN earlier. It looks great! Big difference between the two. I don't like Welds that much, but they look great on there! Weld should use that pic for advertising. Very Nice!
Thanks for the comments guys! It looks like you're big ballin'. You sure do have a lot of cars and bikes in your sig. Where do you park them all? Which is your most favorite?
I'll see if the 8" 4BS are available. 5" BS will work on a 10" wide rim? No body frame/wheelwell mods are done and I'm trying to avoid it.
Given that you recommend...
18x8 4" BS
18x10 5" BS
Thanks for the help!!!!!!!!!!!!
Oh... longer studs necessary?
Hey nero, Are your fender lips trimmed at all?
Heres a pic of a GN I had(center). It has 18x8.5 w/4.5 bs all around and the fronts rubbed a little..even with the lip rolled some. Also, You may wanna go with a 5" bs on the rear if you go with a 10" wide wheel..maybe go with a 8" wide in front too.
The wheels in the pic? If so, They are MHT's and were on the car when I bought it.
BTW, In the new GMHTP they fitted a TR with 5.5 bs wheels.
QUOTE]
Can you help me out with something. I can't figure out how 2 wheels of the same width can have one with 15mm offset and one with 35mm offset and they both claim to have the same size wheel lip. Check out this website with the axis wheels that you have. I just can't figure it out. I don't want to buy these particular wheels but I wanted to understand the concept. Doesn't the offset effect the back spacing and of course the placement of the wheel center in the wheel thus affecting the wheel lip?
