b4black
- May 24, 2001
I finally got around to installing the HRpartsNstuff polyurethane motor mount. I went with just the driver's side, since this is a "low power" application . Before the mount, the engine looked like it wanted to climb out of the compartment. Go open your hood and push the gas while standing on the brake. All that engine movement causes the downpipe to bang into everything which sets off a lot of false knock.
I also added a brace to the bottom of the downpipe to keep it from resting on the header. This and the poly mount cured almost all of my knock problem. The poly mount isn't cheap, ~$85 and it does cause some vibration. Paul Ferry says there a softer version coming out- I would wait for that. If there the possibilty of a 4.1 in your furture, get the second design that's machine for the 4.1/stage block.
You can try a torque strap for much less, but this is a quality peice worth the money, IMO.
CHECK THIS VIDEO OUT!
http://www.caro.net/sully/temp/hrparts.wmv
Looks pretty cool if you view it full screen!
Steve S. down in NC is graciously doing some testing for us with a new pair of Poly Motor Mounts. The link is to a video that has 4 parts:
1) Stk mounts idling
2) Stk mounts light brake torque
3) Poly mounts idling
4) Poly mounts light brake torque
The motor with the stock mounts looks like it is going to jump right out of there! And he didn't even plan on getting a set right now, but he is REALLY glad he has them now! I can't imagine what the alternator or accessory bracket would look like if it had a strap on it. Way too much stress to be putting up there. Thought you all would get a kick out of seeing this.
__________________
Paul Ferry
www.HRpartsNstuff.com
"Home of the Poly Motor Mounts"
"Better Design = Better Performance"
E-mail: HRpartsNstuff@aol.com
Phone: (330)678-0899
FAX: (330)678-8244
