I've got a popping problem with my GN and i've run out of ideas.
Anytime i go over 4500 rpm in any gear i get a miss or a pop. Directscan and Scanmaster show anywhere from 1-4 degrees of knock the entire run. O2s are 830-820. I'm only running 14 lbs of boost with straight 110 and joe Lubrant street chip. It does the same with the ME-R on it too. I've replaced wires, plugs, coilpacks, modules, fuel filter, rebuilt the fuel regulator and put in a new 340 pump. I pulled the intake off to check the cam and lifters and both look good. I also installed some adjustable pushrods and set the preload to .035".
I put a set of Champion iron heads and intake on along with a set of Cometics.(new 980 springs too) I'm starting to wonder if there's a problem with a head gasket. It does'nt leak water.
My TE44 is getting pretty sloppy also. I noticed some oil in the intake when i checked the cam. Would oil in the comb. chamber cause this bad of a pop?
Here's some of the combo: TE44,55s, 340 pump, 206/206 Webber, Champion irons.
TIA!
TIA!
