Hey Kev, B4 you "get your panties wrapped around the axle", how bout some more info??
1. Do you have a scan tool? Readings??
2. Just what does "tuning" mean? What did you do to the car?
3. Did the problem surface B4 or after the "tuneup"??
4. Has the car been subjected to the famous "spring cleaning" process?
5. What mods are in place?
A. Adj FPR?
B. Plugs and what gap? Plug wires?? New, old, etc?
C. Fuel pump and hotwire?
D. Electrical system mods such as volt booster?
6. What tools do you have to test with? Coil pak tester, VOM, GOOD fuel PSI ga., compression ga., ETC, ETC.
7. How many miles on the car?
Given the problem as described, is more than likely electrical, as already said, I'd do a MAF tap test, clean and tighten ALL grounds, clean and lube all connectors,sweep the TPS w/ the VOM to see if it has a bad winding, check alt output and battery volts w/ engine at idle.
Look to see that the POS cable has not gotten into contact w/ the DP. [Could be a bad motor mount]
You can OHM the coilpak.. Best method is the tester from Caspers!!
I doubt the boost solenoid would make the car act as you described. I believe the cliking is the ECm verifying the presence of the sol. on startup.??
Has the cam sensor been out of the engine? Is it loose?
Has the crank sensor been checked for proper air gap and being secure in the mount? While you are there, check to see if the balancer is loose.
Once all this is done, get back to us and let us know what you've found.
