Turbo-Rich
ALBATROSS
- May 25, 2001
Going to work last night I punched the gas a little bit at about 20 mph on the usual stretch of road just after comming to a stop. The engine fell flat & quietly popped then resumed acceleration. I let off & everything seemed ok. I tried mashing the peddal again & the same thing happen's. This has never happened before but I have only been driving the car a few weeks & it does have an exhaust leak on the pass. side manifold. Still, this is a first.
On the way home this morning I tried mashing the pedal from a standstill. It immediately popped a few times & stumbled then took off. I then tried a power brake launch. It powerbraked fine but stumbled terribly when I got off the brake & mashed the pedal then it accelerated fine to a yellow boost light when I let off. I played around a little more & found out that it will accelerate & make boost fine if I ease into it insead of stomping the pedal all at once. It also seems like if I have the RPM's up THEN mash it everything is normal. Going down the road at about the point that I start to hear the turbo whistle(sorry, no boost guage on this one yet) & mash it is when it seems to be the worst(besides the powerbrake). I know that in the other 'T I can powerbrake right to the point of 0lbs. of boost & that's also about the time I start to hear that wonderful whistling noise. What I am trying to say is that it SEEMS to be doing this at or around the point of spool up. The only other thing that was out of the norm. was that when I started it this morning, I couldn't kick the choke down with the gas pedal like I always do before I take off. It was unusually cool this morning tho. That's probably why the choke stayed on. It did seem to go off after a few blocks.
I haven't checked nothing yet. I'm going to start with the timing. Then look for disconnected vac. line's. Any other suggestions
It kind of feels like the timing isn't advancing
