Ported champion Irons + Extras
turboluke
Ported Champion iron heads with T&D 1.65 Roller rockers with push rods and arp head studs. I bought them about 6 months ago used. The person I got them from said they had a few hundred miles on them and I believed him buy the way they looked. I never ended up using them and now going a different direction. The heads are set up for a roller cam. The cam he said he used was a comp 212. I don't have the cam or lifters. I do not want to separate. $1200+shipping
hmmmm My grandparents are in Dixon, might be headed out that way to pick up a car soon....
I will also have some more stuff for sale turbo te60 razor alkey kit, 80 lb injectors, power logger plx wide band rjc power plate,etc. All like new. Let me know I make you a package deal. LOL
You know if Bison jumps on them it's a good deal ;). My god Bison, how much storage do you have? Are you starting a museum?
I'm not sure what em is but you would think he has plenty of em by now.
Stuff comes and goes. I usually convert these for use with aggressive cams (hyd or solid)and make sure they are 100% before they go out. It's quite a bit of work and $ outlay to get to that point. Springs, locks, retainers, machining for the springs, re-surfacing, checking valve seats, guides, and or re-grinding seats, assembly time, etc. Typically they are sold before I have them completed and I hardly ever list them for sale. One thing that is for sure is the buyer has a huge advantage over other setups if the cam and rest of the combo is tight. the ramp and rpm potential is extended way beyond what they were. More duration where it's needed, less overlap, and higher cylinder pressures across the board.
