Ported intake
JUSTA3.8V6
Hey guys, just wondering if it is worth it to go with a ported intake from champion? I just got heads from him and don't want anything restricting the capabilities of them.
Sir,
Stock intake will out flow the heads. BUT!!! it can be worked on to help direct the air thru the runner of the head.
Bob
Yea don't worry about the intake, just clean up the buggers and the end of the runners and around the injector holes
Yupp.. and at the end of the day in a back to back comparison.. you will find out it is worth a great big ZERO ! .. but it sure does look pretty :)
Well as long as it's a big zero....and at the end of a Friday.
Do you plan on doing anything else to the motor? How do you intend to use the car in the future? What are your goals? If you're going to keep upgrading it's easier to do things like heads and intake at the same time. How's the bottom end?
Put a 210/215 roller cam in from full throttle and champion ported irons. Bottom end is stock.
